Re: 400 farmall Deisel
Posted by 26Red on October 02, 2003 at 15:19:26 from (170.92.1.104):
In Reply to: 400 farmall Deisel posted by Allisrules on October 02, 2003 at 14:17:52:
I'm not sure if you really can do that. The head is designed with a precombustion chamber for starting on gas. Butterfly valves close it off when running on diesel. Get a operator's manual from binder books dot com. Follow the start up and shut down procedures to the letter or you may end up with a warped starting valve or cracked head. These systems work well when they are setup right. Sometimes you can start it directly on diesel if the motor is hot(previously running within 30 minutes). Maybe the guys on the puller forum can help you with your direct start mods.
Post A Followup
: Re: Re: 400 farmall Deisel
