Re: PTO Generators
Posted by Roger on October 03, 2003 at 17:33:17 from (216.248.104.132):
In Reply to: PTO Generators posted by steve in va on October 03, 2003 at 16:48:40:
Steve, I have a 20 or 25000 watt (can't remember which it is). I got it after we had a major ice storm here in NW Iowa back in 1991. I've never tried to run it with my Farmall F20 & the next bigger tractor is a MM UTI 40 hp & I know it runs the generator ok. As far as how "pure" the power is that it puts out, I'd want to check it with an oscilloscope before hooking it up to the house since there are so many sensitive electronic gadgets around here anymore. Keep one thing in mind, no matter how big the generator is, whatever is hooked to it will only draw what it needs to run. It's when you hook up too many things is when you run into problems
Post A Followup
: Re: Re: PTO Generators
