Re: 656D Specs.
Posted by TL on October 06, 2003 at 03:58:19 from (206.162.192.40):
In Reply to: 656D Specs. posted by Tim Severson on October 05, 2003 at 20:12:23:
According to the manual it shows no difference between gas or diesel.Based on 15.5-38 r-1 tire.1st normal 2-1/2,ta 1-3/4.2nd normal 4,ta 2-3/4.3rd normal 5,ta 3-1/2.4th normal 7,ta 4-3/4.5th normal 16,ta 10-3/4.rev normal 2-3/4,ta 2 .This is at 1800 rpm.There is a difference on hydro.1st F 2-1/2,R 3.2nd F 4,R 5.3rd F 5,R 6.4th F 7,R 8-1/2.5th F 16,R 19-1/2.With 16.9-34 r-1 tires 1-1/2 percent less,With 14.9-38 r-1 and 18.4-34 r 1 tires 3 percent greater.
Post A Followup
: Re: Re: 656D Specs.
