Re: Farmall A Cultivator help!!!!
Posted by gene b on October 06, 2003 at 19:28:59 from (67.1.98.107):
In Reply to: Farmall A Cultivator help!!!! posted by Mark on October 05, 2003 at 11:30:50:
There is th A-136 and the A-138 also the A-435 veggie set up. Does yours have the pipe frame or the rect one also manual lift or exhaust. You need the operaters manual it shows all the different types of tooling. I have several ones but not the pipe frame one. Try and find the manual it will answer all your questions.
Post A Followup
: Re: Re: Farmall A Cultivator help!!!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
