Re: Re: overhauling 656 gas
Posted by karl f on October 06, 2003 at 20:48:19 from (64.94.14.80):
In Reply to: Re: overhauling 656 gas posted by Aces on October 06, 2003 at 20:19:24:
the rod bearing and main bearing i have inspected (and had the parts store inspect) show considerable wear, and some spots are unevenly worn. thrust surfaces show copper, and there is a small scored spot. so the crank probably should be inspected and at least polished.
-k
Post A Followup
: Re: Re: Re: overhauling 656 gas
