Farmall Tractors Discussion Board
Re: 3-Point for an H
Posted by john d on September 28, 1999 at 14:48:42 from (206.141.74.34):
In Reply to: 3-Point for an H posted by Jon with an H on September 28, 1999 at 07:36:26:
3pt makes the H a much more versatile tractor. Some types will let you end up with a fixed hitch, or drawbar instead of just a piece with holes between the lift arms. The ones with the fixed hitch are generally preferable.
You can find arrangements that use 1 cylinder, or two; if your lift is in good shape, 1 cylinder may give you all the power you need for hanging weight on the back of an H.
You hydraulic system is single acting - therefore it will extend the cylinders, or retract them, but not both. 2-way action with this system requires lots of extra plumbing.
If you hang a lot of weight on the 3pt, you may need an adjustable flow-control valve in the line to allow free lift, but restricted drop. Otherwise... things will drop in a big hurry! These are not expensive, and can be obtained from about any hydrualics supply place.
Post a Followup
: Re: Re: 3-Point for an H
