Re: Re: H cam gear broke
Posted by Norm on October 08, 2003 at 18:54:43 from (66.231.127.57):
In Reply to: Re: H cam gear broke posted by Aces on October 08, 2003 at 18:23:18:
Aces
It seems if you tighten it all the way the gear will hit the back plate. The hub should be out right. The back side is recessed in so there is nothing to tighten too. There was a scar on the back plate in one spot like it was rubbing. When I took it apart it was about 2-3 turn out with the locking washer on the nut so I don't think it loosened up from the last time it was apart. There would not be some shims that go behind? Thanks Norm
Post A Followup
: Re: Re: Re: H cam gear broke
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
