Re: international voltage regulator
Posted by Bob M on October 09, 2003 at 04:32:02 from (165.170.128.66):
In Reply to: international voltage regulator posted by Bart on October 08, 2003 at 14:31:23:
Bart - here's a couple suggestions... 1 - Peek under the regulator cover. If there's only 2 relays inside it will be a 6 volt unit. If you find 3 relays, the regulator can be either 6 or 12 volt. 2 - If you have a variable voltage DC power supply, remove the regulator cover then do this: Connect one power supply lead (doesn't matter which one...) to the GEN terminal and ground the other on the regulator base. Now watch the cutout relay (it's the one whose contacts are held OPEN by spring pressure) while you slowly increase the power supply voltage starting at 0 volts. If the relay contacts close at about 7 volts you have a 6 volt regulator. And if it closes around 14 volts, the regulator is for 12 volts. 3 - Don't have a variable DC supply? Then feed 12 volts from a car battery to the GEN and regulator frame as above. If the cutout relay closes it's a 6 volt regulator; if the cutout doesn't close it's 12 volt.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
