Re: Farmall B timing
Posted by Gary_N_WV on October 09, 2003 at 11:11:48 from (129.71.234.254):
In Reply to: Farmall B timing posted by jim in ky on October 09, 2003 at 10:37:04:
Jim,
I think your B engine is the same as my C ---someone will correct me if I'm wrong---
On my C, I couldn't find a pointer of any kind, so I took # 1 plug out and watched the piston come up to the top of the cylinder, then I looked at the rotor button to make sure it was pointing at the # 1 wire which is suppose to be at about the 2 o'clock position as you look at the top of the distributor.
Then I watched the points to see when they opened and backed it up a little to the point where they were just getting ready to open and then tightened the distributor down enough that it wouldn't move on its own.
After I replaced the cap and etc, it fired right up.
After it was running, I moved the distributor each way until the engine ran best.
I figure I might have to "tweak" it a little after I get all the tractor back together to actually use it.
Hope this will help some !
Gary
Post A Followup
: Re: Re: Farmall B timing
