52 super M oil in water
Posted by Nathan on October 10, 2003 at 07:32:13 from (24.56.94.97):
I am fixing to buy a 52 Super M. The motor was rebuild about three years ago to 450 specs(so i am told)and has not been run but maybe 5-10 hours since then. Fires up and runs great with no smoke. Problem is when you pull the drain plug on the oil pan you get a half to full gallon of water out before the oil. Where would you start to find the problem. Head gasket? This will be my first tractor to tear into. thanks Nathan
Post A Followup
: Re: 52 super M oil in water
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
