Re: Liquid block sealer being used in thermosiphon
Posted by James Williams on October 11, 2003 at 17:41:46 from (170.215.132.77):
In Reply to: Liquid block sealer being used in thermosiphon sys posted by Jonathan Mirgon on October 11, 2003 at 08:49:46:
Jonathan,I used a block sealer on my F12,I think it was k&d or something like that,It was the metalic type sealer,and it worked perfect.The way I under stand you must follow directions.Flush all antifreeze out of motor,mix sealer with hot spigot water, run for at least one hour at a steady speed,do not rev up,several hours would be better,turn motor off,let cool,drain water out of motor,let sit empty for atleast 24 hours or longer,than refill with coolant.
Post A Followup
: Re: Re: Liquid block sealer being used in thermosiphon
