Re: Magneto Timing.......Is there such a thing ?
Posted by MD Wa. on October 11, 2003 at 19:43:12 from (65.239.11.98):
In Reply to: Magneto Timing.......Is there such a thing ? posted by Scotty on October 11, 2003 at 18:42:30:
Scotty.
If you clean the gears good you should see on one gear two teeth that have been ground down just a little. On the other there will be one tooth that has been ground, that tooth goes between the two on the 1st gear. LOL Morgan
Post A Followup
: Re: Re: Magneto Timing.......Is there such a thing ?
