Re: timing mark for 656 farmall
Posted by K.B. on October 12, 2003 at 19:01:19 from (209.163.43.40):
In Reply to: timing mark for 656 farmall posted by scott louque on October 12, 2003 at 17:57:54:
Go to your local farm store and pick up the I&T Service Manual for the 656. They cost a little over $20, and it will describe the timing process in detail. There is a cover on the side of the clutch housing held on by two 1/4" bolts, the timing marks are on the flywheel, and you can use a prybar to turn the engine over by the flywheel ring gear. Don't try this without the manual, you need to know exactly how many degrees before or after TDC the engine needs to be, and you need to remove a cover from the side of the pump and line up two marks.
Post A Followup
: Re: Re: timing mark for 656 farmall
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
