timing mark for 656 farmall
Posted by scott louque on October 12, 2003 at 17:57:54 from (68.108.230.229):
i recently had the injector pump on my 1967 farmall 656 reworked and the injectors rebuilt.(pocket book still hurts) naturaly someone turned the engine over while the injector pump was in the shop. lost the timing. called two different dealerships to ask them where to position the engine to re time it and got two different answers.
does any one know the correct timing mark or procedure to find it.
the engine is a D282 serialnumber 90905
tractor serial is 2450135U045717*
Post A Followup
: Re: timing mark for 656 farmall
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
