Re: timing mark for 656 farmall
Posted by chris on October 12, 2003 at 21:32:16 from (65.66.76.78):
In Reply to: timing mark for 656 farmall posted by scott louque on October 12, 2003 at 17:57:54:
if you still have trouble call me 8 to 5 at 1 501 354 1833 ask for chris this is my work a case dealership ill see if i can help you
Post A Followup
: Re: Re: timing mark for 656 farmall
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
