Re: Re: Re: 450 Farmall Thermostat
Posted by Bob M on October 13, 2003 at 09:39:22 from (165.170.128.65):
In Reply to: Re: Re: 450 Farmall Thermostat posted by Joe on October 13, 2003 at 07:50:24:
Jimmy - Your setup there will probably indicate temperature OK. However it'll be slow to respond to a sudden overheating situation (like should the fan belt break or the thermostat stick shut). If you don't use the block heater I'd take that tee and stuff off and screw the temp gage bulb directly into the head.
However if you want to keep the heater you might do this: Remove the tee and nipple from the head. Take a close (short) nipple, screw it into the head, then screw one of the run outlets of the tee onto the close nipple. Then screw the temp gage bulb into the other run outlet, and the heater hose into the side outlet of the tee. That'll get a portion of the gage bulb into the block where can more quickly sense temperature changes.
Post A Followup
: Re: Re: Re: Re: 450 Farmall Thermostat
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
