Re: Super C Pan Bolts
Posted by Paul Shuler on October 13, 2003 at 18:02:34 from (170.29.1.10):
In Reply to: Super C Pan Bolts posted by Bud on October 13, 2003 at 15:41:12:
I'm not sure if I understand your question for sure. All the bolts go through the pan, through a hole in the gasket and then into the threaded holes in the block. The holes in the four corners if I remember right are longer than the rest of the bolts.If you have a good gasket and nothing is bent on the pan and all the bolts are to proper torque then you shouldn't have a leak.I once had a rear main leak I could have swore it was the oil pan but it was running down then dripping off the same bolt all the time.
Post A Followup
: Re: Re: Super C Pan Bolts
