Re: Farmall MD Carburetor
Posted by brianh on October 14, 2003 at 06:20:47 from (69.48.41.2):
In Reply to: Farmall MD Carburetor posted by Troy - MI on October 13, 2003 at 12:57:27:
The idle speed is set by adjusting the clearance between the throttle plate that sets above the body output hole and the body. I believe the book spec is like 9/64" but I'm not positive. Some of the carbs had a spring below the plate that held it up and you could adjust the idle speed by turning the mounting screw. On mine, it is mounted on a stud, so you would have to shim up or turn down the stud to adjust the clearance.
Post A Followup
: Re: Re: Farmall MD Carburetor
