Re: wet sleeve removal question
Posted by Dale in Ar. on October 15, 2003 at 06:46:59 from (166.102.153.23):
In Reply to: wet sleeve removal question posted by TedM on October 15, 2003 at 03:12:27:
Ted,wet sleeves are easy to remove and replace,anyway those I've worked on.You can use a block of wood and a big hammer to drive the sleeves out.Going back in is easy,just take your time.The recommened procedure is to clean the area that the rubber o-ring goes in,you can use a wire brush.Take the new sleeve and slide it down into place to see how it fits(WITHOUT the o-ring in place).If all fit good,put o-ring in place,I put dish soap on the outside of the o-ring and on the sleeve.Then slide the new sleeve in place,it should go in easy.You may want to put some copper sealer around the lip of the sleeve where it matches the block and you may want to LIGHTLY tap the top with a wood block and a hammer to make cure it seats.Then add water to the block untill it is full,let set for awhile(like overnight)and check for leaks.I like to use a spacer and washer to hold the sleeves down while I put the pistions in,just in case the sleeve wants to slips.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
