Re: Farmall 140, or Freight Train?
Posted by Phlogiston on October 15, 2003 at 16:51:15 from (65.129.72.59):
In Reply to: Farmall 140, or Freight Train? posted by Greyson O. Noles on October 15, 2003 at 14:04:59:
Start with the most likely cause. Bad head gasket. Pull the head and have a look. White smoke means that you are burning anti-freeze. The reason oil is coming from the fill pipe is that coolant is displacing the oil in the pan and pushing it out. By the way, you are not supposed to take the oil cap off when it is running. Put a new headgasket on, torque it properly and in the correct sequence and see what happens. You will also need to change your oil filter and oil as the stuff in there is now contaminated and no longer protecting your engine.
Phlogiston
Post A Followup
: Re: Re: Farmall 140, or Freight Train?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
