Re: 1941 h
Posted by Farmer Bob on October 15, 2003 at 19:16:30 from (64.113.13.232):
In Reply to: 1941 h posted by pete on October 15, 2003 at 18:38:19:
The governor will be oiled from the engine running. Look at the right side of the block and see the firing order of 1-3-4-2. Rotate the engine until the #1(Front) cyl. is at TDC and check to see the location of the rotor in either your mag or dist. The corresponding post on the cap should be wired to your #1 spark plug. Then go around the cap in Clockwise direction to wire the rest of the plugs (1-3-4-2) and hook up the coil wire into the center post on the Dist/Mag cap.
Just buy two new studs and screw them into the holes on the bottom of the radiator. Available at your local Cas NH dealer or any good auto parts/hardware store. THink originals were 3/8" NC thread on one end and NF on the other. They usually had castelated nuts and cotter keys through the bolster end. Don't forget the rubber pads for the radiator to sit on.
Post A Followup
: Re: Re: 1941 h
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
