Re: Re: Re: Re: Re: Farmall AV's
Posted by Tom on October 16, 2003 at 03:40:58 from (68.169.8.66):
In Reply to: Re: Re: Re: Re: Farmall AV's posted by Slowpoke on October 16, 2003 at 00:55:55:
There was no belt going to the bottom pulley. Unless the bottom pully is under alot of compression, it must be stuck. I could not turn it. There was only 1 belt that went from the fan to the generator, and the belt that should have gone to the crankshaft was missing.
Tom
Post A Followup
: Re: Re: Re: Re: Re: Re: Farmall AV's
