Re: H smoke long....
Posted by R. Marg on October 16, 2003 at 08:37:43 from (66.54.1.38):
In Reply to: H smoke long.... posted by jason r on October 15, 2003 at 21:18:25:
Well as long as it runs good and doesn't foul plugs I'd run it like it is and save up the money to fix it right a whole kit for it runs around $1000 and thtas new sleeves etc and by the way oil is cheaper then parts lol just make sure you use a good oil and you might even use some thing like a 40 or 50 weight oil like valaline raceing I wouldn't use a malti grade since they are thinner
Post A Followup
: Re: Re: H smoke long....
