Farmall Tractors Discussion Board
Re: H steering gear
Posted by The Red on September 29, 1999 at 07:56:51 from (206.246.187.2):
In Reply to: H steering gear posted by Fred on September 29, 1999 at 07:16:16:
Fred more than likely you have wear in both gears. Unbolt the u-joint, reomove the front cap on the upper bolster. You will see a nut with cotter pin. Remove those, then turn the shaft right out of the bolster.
Post a Followup
: Re: Re: H steering gear
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
