m farmall govenor
Posted by Irv Slagter on October 16, 2003 at 18:28:25 from (69.18.21.36):
A young friend of mine called me tonight and said he's got a neighbor with an M with a govenor that is stuck wide open. They've been having trouble with it occasionally and it needed a carburetor kit. They put a kit in it and it ran great unit they took it out for a drive. The govenor stuck open (again) and they can't get it back to the original position. I looked through all the archives and got some ideas but was wondering if it is hard to get the goveror off. I saw the warnings about loosing the balls out of a thrust bearing. Someone mentioned about not putting the throttle on correctly. I haven't seen it yet so am not much help. Can someone shed some light on this. Thanks a lot
Irv
Post A Followup
: Re: m farmall govenor
