Re: m farmall govenor
Posted by Dan on October 17, 2003 at 06:52:21 from (12.18.160.111):
In Reply to: m farmall govenor posted by Irv Slagter on October 16, 2003 at 18:28:25:
I would check a couple things before taking the governor off. The tube betweent he governor and carburator may be jammin it up or the shaft nside my be installed incorrectly in the carb linkage. Loosten it on both ends and make sure the shaft will rotate freely. and that the carb end is installed correctly. You can remove the cover from the governor and see what is happening inside. Could be that there is something stuck inside possibly due to insufficient oil to the governor. Oil to it comes from a passage in the front. Sometimes this gets blocked and so no oil and governor will hang up. I have seen some guys who put and external line to governor to solve that problem. There are springs and bearings inside that may hang up also. You should also check linkage from throttle to governor. May be worn or sticky causing hangup. If you lift hood you can check the part on top of the motor. Nothing realy rocket science there and nothing will fly apart. Good luck on it, always look for the simple stuff first as that is usually where the problem lies.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
