Re: 1941 H Magneto timing questions
Posted by ldreyno on March 30, 2009 at 18:31:23 from (69.81.135.159):
In Reply to: 1941 H Magneto timing questions posted by ldreyno on March 02, 2009 at 17:48:43:
Ok, It is running very nice now. I pulled the carb back apart and checked the new parts against old parts. I noticed the air bleed holes in the main mixing tube were larger on old parts. I put old back in and she runs pretty darn good now. Thinking about it now, I ordered the rebuild kit from the number on the brass tag on carb. Not thinking this tractor was originally Distallate/kerosene. I checked around to find the A/F ratio for kerosene but didn"t find anything. I bet it is a lot richer than gas. Also checked serial number and it is a 1940 not a "41. We have had tractor for about 30 yrs, sometime early in its life it was converted to gas only I assume. Are my observations correct on carb rebuild kit?
