Posted by ldreyno on March 02, 2009 at 17:48:43 from (69.81.135.159):
It has been asked many times and I have been reading the replies. A lot of good information. My problem is self inflicted. Trying to get our H running after sitting 5 years. Sometime in its life the mag had been gutted and converted to a battery/coil setup. I am looking for some clarification on the Distrubutor Gear timing marks. The rotor is marked wih "L" and "R". The service manual states to use "R" for clockwise magnetos. What defines a CW magneto the direction of the Distributor Rotor or the Rotor shaft? I pulled mine apart to clean and grease and didn't notice the 2 markings. I thought there was only one. I re-assembled using the "R" mark since the Distributor Rotor turns CW. She starts but runs extremely rich, my assumption if I am on the wrong mark the ignition timing would be retarded, causing overrich combustion. May be it is time for a re-manf magneto. Thanks in advance for your help
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
