Re: 560 Gas wont charge battery PLEASE HELP
Posted by Jerry on October 19, 2003 at 23:06:48 from (207.173.13.3):
In Reply to: 560 Gas wont charge battery PLEASE HELP posted by Big Red 1 on October 19, 2003 at 06:10:42:
Red:
Did you check your regulator for voltage output with a meter? If it is ok, then check to see if you're getting same volatge at the batt. If you have an AMP guage on the IP, you may want to check to make sure the guage is good also.
Jerry
Post A Followup
: Re: Re: 560 Gas wont charge battery PLEASE HELP
