Charging is this right?
Posted by chad from michigan on March 30, 2009 at 18:51:31 from (67.142.164.24):
Hey I finaly got the Super A charging. I put a different generator on it and things started working. Anyway when the LHDB switch is on low it charges just over "0" I mean just over but if I switch it to high charge the amp meter shows about 12 volts.
Is this right?
Now we have an 8 volt battery on it and I ran the trator with the gen wire un-hooked off the cutout and checked the voltage at the battery while running it showed 8.40 volts then I ran it on high and low charge and it only went up to 8.5 volts on the battery with everything hooked up.
does it sound right?
