Gerator on Super A causing me Grief.
Posted by Brian on October 22, 2003 at 19:51:13 from (65.48.189.192):
I posted a couple of weeks ago that I was have problems with charging on my super A. It is a 6volt system, has the 4 position switch and a mag ignition. Here's what I've done. 1. Had the generator checked out by a local shop, they said that although dirty the generator itself was fine. They gave it a cleaning and it looks good. They did say that the voltage regulator may have been bad and put a new one on. We made sure it was set up for positive ground and it was re-polarized. 2. I checked the wiring to BOB M's diagrams...unless there is something I'm missing it looks good. 3. I checked the continuity in the wires to make sure they were ok and they seem fine. 4. There is 7 volts between the bat terminal on the regulator and ground (bat. volt obviously). My understanding is that there should be more like 10volts when the tractor is running. 5. I have the belt hooked up. 6. I'm pretty sure the gauge works, it worked at the begining of the year showing charge, and when I turn on the lights it show neg. current of about 10 amps. When I run the tractor though it doesn't move to the positve. 7. I've tried the switch in both positions, low and high. 8. I've checked for continuity between the batt terminal on the starter and the gauge, between the gauge and the fuse and the fuse to the switch. I've also check between the amp gauge and the batt terminal on the regulator. I've also got a good wire between the field and the screw which attaches to the resistor that comes on the switch. 9. There is continuity between the screw before the resistor and after, although there didn't seem to be much resistence with the switch in either position. I just can't seem to get this thing to show a charge. Anyone have any suggestions befor I go bald from pulling my hair out ? I'm in the dark here. Thanks for you replies.
Brian.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
