Re: Gerator on Super A causing me Grief.
Posted by steve on October 23, 2003 at 19:31:05 from (204.246.222.80):
In Reply to: Gerator on Super A causing me Grief. posted by Brian on October 22, 2003 at 19:51:13:
the light switch is used to ground the "F" terminal of the generator. bypass the switch by running a wire from "F" to ground.
--start tractor and see how that works. if the amp meter does not show a few amps charge and volt meter show slight charge, then...
--- Take the "G" terminal and "B" terminal wires on the regulator and connect together. this will bypass regulator and run generator "A" to the ampmeter, then thru ampmeter to battery. (other side of battery is gound)...
--start tractor and note charge, the regulator is out of the system and the generator should go to "full charge" which will only be 10 amps. you can run this way for several minutes for a test.
--you have now narrowed down if you have a good switch, if the regulator is working, and if the generator is putting out power.
--by the way, if you take the wires off the generator and ground the "F". then startup the tractor and measure voltage across the A and F terminals (A connected to nothing) you will get probably 10-15 volts output. it is the battery and regulator that adjust it down to 6 volts.
Post A Followup
: Re: Re: Gerator on Super A causing me Grief.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
