Re: painting rims with tires mounted
Posted by Ron in Nebr on October 22, 2003 at 21:32:15 from (65.165.16.78):
In Reply to: painting rims with tires mounted posted by Jay on October 22, 2003 at 20:09:58:
A trick I heard was to smear a thin coat of Vaseline on the tire sidewall, then when you're done painting you can just wipe it off and the tire will be clean.
Post A Followup
: Re: Re: painting rims with tires mounted
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
