Re: painting rims with tires mounted
Posted by Catskill Pete on October 23, 2003 at 11:50:24 from (205.232.37.136):
In Reply to: painting rims with tires mounted posted by Jay on October 22, 2003 at 20:09:58:
I have come full circle on rims, used to brush paint them, then tried masking, grease, soap etc. to spray them. All the masking proved to be just as time consuming as the brush did and difficult to remove afterward. So I'm back to the brush, However there is a "secret" to a nice brush job. Apply the first coat and it will look terrible with all the brush strokes and thin spots showing through, But wait for first coat to dry [usually 24 hours] and apply a second coat fairly heavy and it will flow into the brush strokes and dry to a nice smooth finish. It works with aluminum or colored paints.
Post A Followup
: Re: Re: painting rims with tires mounted
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
