Re: Re: Re: Re: Over charging Generator
Posted by Walt on October 24, 2003 at 18:40:04 from (170.224.224.102):
In Reply to: Re: Re: Re: Over charging Generator posted by Bob M on October 24, 2003 at 12:57:25:
Check your regulator. If it has 3 coils and point sets in it it is a late model and can be adjusted. The voltage should be no more than 7.5 volts. This works on all 6 volt systems. The current portion of the regulater should be set for about 25 amps. This will give you a place to start fine tuning with a late model setup. Hope it helps.
Walt
Post A Followup
: Re: Re: Re: Re: Re: Over charging Generator
