Re: Retrofitting a Farmall A with hydraulics...
Posted by Haas on October 25, 2003 at 10:42:00 from (12.65.42.117):
In Reply to: Retrofitting a Farmall A with hydraulics... posted by Jesse on October 25, 2003 at 09:42:07:
You can mount a small hydraulic pump on the front of the engine and drive it off the generator belt. Northern tool has some little hydraulic pumps designed for belt drive. Then you just need some hoses, a reservoir for the oil and a control valve. Then you will be ready to hook up to a cylinder.
Post A Followup
: Re: Re: Retrofitting a Farmall A with hydraulics...
