Re: Re: Re: 200 Fuel Tank Shutoff Valve Parts Sour
Posted by Slowpoke on October 26, 2003 at 21:30:51 from (67.30.99.156):
In Reply to: Re: Re: 200 Fuel Tank Shutoff Valve Parts Source posted by David Knapp on October 26, 2003 at 12:55:26:
All the shut-offs I have seen use a T handle. 'String packing' material for stems is avalilable at the hardware. It's about 3/32 in diameter. Of course it's for water, but it's inexpensive to try. Wrap it around the stem and tighten the nut. As a last resort, straighten the handle, replace the stem seal with a like material,and figure out how to make a T handle. Maybe some JB Weld and brass tubing from the hobby shop will work. Each size tubing will just slide in/over the next size. The gas line most likely uses 5/16" compression fittings, consisting of a double tapered ring (sleeve) and a female nut. When the nut is tightened, it forces the sleeve against the tube and the between fittings. It will not leak if the tube and fittngs are clean and not bent or damaged. You can use a small amount of anti-seize on the threads to make it easy to remove later. Sealant is not necessary on straight thread fittings; it's only used on tapered threads like water pipe. I just paid 9¢ each for 5/16 sleeves and 19¢ for the nuts at the hardware. They're also available at the auto supply. If you have leaks from the gas line, buy some copper tube and fittings to make a new line. I hope this gives you some ideas you can use.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
