Re: my farmall a
Posted by Dave_Id on October 27, 2003 at 12:14:33 from (67.0.146.175):
In Reply to: my farmall a posted by tractorhead on October 27, 2003 at 12:03:23:
The pins were installed perhaps, at the end of the crack to keep from cracking further. This type of crack is very common on this engine, and is not under pressure, so go ahead and repair with JB weld, it'll be fine... Maybe carb problem has something to do with dirt in tank. remove drain plug on carb bowl to see if you got a good steady flow, if you don't, you have a problem other than carburator.
Post A Followup
: Re: Re: my farmall a
