Re: Splitting a BN for clutch
Posted by Kevin on October 27, 2003 at 14:24:12 from (198.108.144.111):
In Reply to: Splitting a BN for clutch posted by Steve W on October 27, 2003 at 09:13:16:
We were able to make a pretty simple stand by using three pieces of angle iron. Lay one on the floor and weld the other two standing up wide enough to bolt on to the cultivator mounts on the bell housing. If you are skilled enough I've even seen some with casters on it so you can move the whole assembly around.
Post A Followup
: Re: Re: Splitting a BN for clutch
