Re: Front Bolster Removal on Farmall M Wide Front
Posted by Bob M on October 28, 2003 at 04:35:00 from (165.170.128.65):
In Reply to: Front Bolster Removal on Farmall M Wide Front posted by Mr. J on October 27, 2003 at 19:25:52:
Jared - You'll need to remove the entire front end assembly. Best way probably is to do it as a unit (radiator, bolster and front axle). First drain and disconnect the radiator hoses, disconnect the steering shaft at the U-joint, and disconnect the WFE stay rod bracket under the tractor. Then remove the bolts holding the upper bolster to the frame rails, and loosen (but don't remove) the other frame rail bolts. Finally use a suitable hoist or loader to slide the bolster/front axle assembly ahead and away from the tractor. BE CAREFUL HERE - the assembly is VERY top heavy!
Punch below for a few pix taken when I replaced the cam gear on my Super M a couple years ago. Mine's a narrow front - however except for the front axle stay rod, bolster removal will be the same for your WF tractor.
Good luck!
Post A Followup
: Re: Re: Front Bolster Removal on Farmall M Wide Front
