Re: Re: Adding a wide front to my 400
Posted by sod on October 28, 2003 at 08:46:35 from (209.206.151.49):
In Reply to: Re: Adding a wide front to my 400 posted by Ohio Bill on October 28, 2003 at 07:48:16:
Instead of buying a tap, cut some slashes in a bolt (lengthwise) and use that for a tap.
You will have to clean it more, but for limited use...
good luck
sod
Post A Followup
: Re: Re: Re: Adding a wide front to my 400
