Re: rocker arm assembly
Posted by rustyfarmall on October 28, 2003 at 14:00:11 from (207.32.13.194):
In Reply to: rocker arm assembly posted by Buster here again... on October 28, 2003 at 11:09:28:
If you have removed the head, you will need to adjust the valve lash, even if you hadn't touched the rocker arm.
Post A Followup
: Re: Re: rocker arm assembly
