Re: Farmall model A cylinder walls
Posted by Steve - IN on October 29, 2003 at 16:46:48 from (12.222.30.13):
In Reply to: Farmall model A cylinder walls posted by Mike on October 29, 2003 at 15:11:50:
Mike,
I think your spec is the compression the cylinder makes - and there's no set tolerance for how much stuff built up at the top.
You'll pick up some cranking compression from the valve job. As long as you're not doing a complete rebuild, leave the ridge as it is.
Post A Followup
: Re: Re: Farmall model A cylinder walls
