Re: first overhaul a success
Posted by Allan on October 30, 2003 at 03:35:26 from (148.63.132.164):
In Reply to: first overhaul a success posted by karl f on October 29, 2003 at 19:59:38:
Karl,
That seems odd having condensation on a brand new overhaul. I think you do need to put it to work and run it up to temp for a time to see if that condensation stops. Is she breathing out the tube okay?
One would normally see condensation on engines that are started and stopped without ever allowing them to warm up. The engine cannot develop enough heat to burn the moisture off.
Just a thought,
Allan
Post A Followup
: Re: Re: first overhaul a success
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
