Re: Plough set up
Posted by Haas on October 30, 2003 at 04:47:12 from (12.65.72.64):
In Reply to: Plough set up posted by Kurow on October 30, 2003 at 01:48:37:
I think you have it right. Reverse the drawbar and put it on the front of the two mounting locations on the final drives and bolt the plow to it. Then you will need rear lifting arms and a way to adjust the height of the drawbar to control the tilt of the plow. You can use the plow without the bar to adjust the front of the drawbar, but you will need to adjust the drawbar to the lowest position with the bolt on the drawbar bracket.
Post A Followup
: Re: Re: Plough set up
