Re: Does TA work in reverse
Posted by Red Dave on October 30, 2003 at 08:33:44 from (24.104.94.34):
In Reply to: Does TA work in reverse posted by ftmerle on October 30, 2003 at 08:10:48:
The TA's I have run worked the same forward or reverse. The TA is ahead of the transmission and would turn the same way going either direction.
I suggest that you get the manual and carefully follow the adjustment procedure before doing anything else. Might be enough to correct it.
Post A Followup
: Re: Re: Does TA work in reverse
