Re: What fluid for power steering 400 rc
Posted by TP from Central PA on October 30, 2003 at 12:10:23 from (205.188.209.82):
In Reply to: What fluid for power steering 400 rc posted by Kelly C on October 30, 2003 at 06:17:51:
If it is "Factory" it gets its oil from the hydraulic system on the tractor.........Which takes hytran........Also since it has a loader on it and the system has seen some use I would drain the reservoir and clean the filter..........If it has Charlynn PS on it, with its own pump and reservoir you can use PS fluid, hydraulic fluid(Any) or hy-tran..........I have been around Charlynn systems to know one thing, if it isn't leaking it probably isn't working ;-D Will add more later, gotta run now!!!!
Post A Followup
: Re: Re: What fluid for power steering 400 rc
