Farmall Tractors Discussion Board
Re: Getting more power from a distilate Super M
Posted by john d on September 30, 1999 at 17:56:01 from (206.141.74.34):
In Reply to: Getting more power from a distilate Super M posted by Joe Berendzen on September 30, 1999 at 13:28:36:
The small tank would indicate a distillate engine. The head would likely be a lower compression head than used on a gasoline engine. Increasing compression ratio should increase power. Bear in mind, however, that a tractor of this age may have been overhauled in the past with precisely that purpose in mind. 30 - 40 years ago you could easily buy sleeve and piston sets in combinations which would push the compression ratio up on a distillate engine to levels which were comparable to a gasoline engine. We did this on a '43 H which was built for distillate fuel.
Check to see what pistons may have been installed before investing in a new head. IH, M&W, and some other companies made sleeve and piston sets that could bump up the ratios to about the limit of what the engine could stand for serious field work.
Post a Followup
: Re: Re: Getting more power from a distilate Super M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
