Re: Why won't these sleeves budge?!!
Posted by Jonathan Mirgon on October 30, 2003 at 18:01:31 from (205.208.129.147):
In Reply to: Why won't these sleeves budge?!! posted by Brad on October 30, 2003 at 17:10:44:
Yes I can sense your frustartion I had the same problem when restoring my (a) engine. I cant remember which was harder : getting the sleeves out or the new crank pulley on. It sounds like you have pretty well tried everthing. Where I work we have a huge press , I ended up taking the block to work , turning upside down and using the press, they popped right out then. You may have to end up taking to a machine shop with a large press. The other other thing you may try is to pack one of the liners with (dry ice) and let it sit a little while this may shrink your liner enough to allow it to come out. If you try that and it works let me know. I have heard of people using this method.
Post A Followup
: Re: Re: Why won't these sleeves budge?!!
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
