Re: no fire to distribitor
Posted by Steve140 on October 30, 2003 at 19:52:02 from (216.196.171.108):
In Reply to: no fire to distribitor posted by Huston Lloyd on October 29, 2003 at 18:10:07:
Huston, do you have fire at the coil ? on the 140 there is a wire that runs from the hot side of your ignition to the coil it runs along the left side of the tractor in the wire loom. it should have a connector to the ignition switch behind the panel check the wire connection on the coil make sure its hooked to the Ign side of your coil then check and see if you have power there with switch on? if not run a jumper from battery to the coil and try to start the tractor if it fires up you need to start tracing the Ign wire first place to look for a problem after the coil is behind the dash panel the previous owner of my 140 could not get it to start it cranked but no start i found the wire disconected behind the panel tractor gave same symtoms as yours
Post A Followup
: Re: Re: no fire to distribitor
Today's Featured Article - On the Road with Dave Gohl: Auction Musings - by Dave Gohl. I was thinking the other day about all the auctions I've been to in the last few years. There've been many. Some have been very good, some have been well, disappointing to say the least. But no matter how good or bad auctions may be, we always seem to stay until the item we've come for or are interested in is on the block. I've been to some auctions near and far. I think the furthest has been the Two Cylinder 7 in the Amana Colonies last year. Lots of stuff, lots of people. I've also atten ... [Read Article]
